serpentine brackets
Old Jul 5, 2008 | 11:26 PM
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
Transmission: TKO-600 5 speed
Axle/Gears: 3.73 10 bolt
serpentine brackets
is there anywhere that sells all of the accessory brackets you would need to run a third gen serpentine setup.
Looking to buy a set for my 97 yukon with a 350 vortec motor in it because the accessories are designed in the most rediculous way ever.
Old Jul 6, 2008 | 06:44 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: serpentine brackets
I'm not sure the following is what you're searching for, but....
https://www.thirdgen.org/forums/afte...rsion-kit.html
JamesC
Old Jul 6, 2008 | 01:08 PM
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
thats perfect, for that price tho seeing as how i dont need air ill probably see if i can just rob a third gen in the junk yard for one.
afaik everything before the Gen 3 blocks had the same bolt holes for accessory brackets, all i should need is the water pump because on the vortec motors its reverse rotation, so a camaro water pump and i should be off to the races
Old Jul 6, 2008 | 01:17 PM
JamesC's Avatar
There's a non-AC kit available as well. Yes, you'll need a reverse rotation water pump.
JamesC
Old Jul 6, 2008 | 05:39 PM
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
ya ill be keeping my a/c just converting some of the lines
the vortec setup is just retarded the a/c pulley is on the drivers side, the bracket covers the top of the valve cover to the point where you cant get the cover off without unbolting the bracket
and the a/c lines run accross the front of the intake, going to try to convert it all to a serpentine setup, re-do the a/c lines so i can keep my a/c and put a tpi intake on the truck
jrdturbo
Mar 31, 2016 02:58 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
jovibuilt
Exterior Parts Wanted
Oct 18, 2015 08:12 PM
meeklay812
Oct 1, 2015 03:46 PM
armybyrd
Sep 26, 2015 03:37 PM
