Performer RPM: What are all these ports??
Old Jul 8, 2008 | 03:02 PM
davep_96's Avatar
Car: 1987 Trans Am GTA
Engine: 355
Transmission: TH-700r4
Can anyone tell me/give me a diagram of an Edelbrock Performer RPM Vortec intake that tells me what all of the ports on it are for. I know some are for vacuum and water, but which ones are which? And are there ports for other things as well?
Old Jul 8, 2008 | 03:08 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Performer RPM: What are all these ports??
the ports on the intake runners are for vacuum, the ones on the water passages front and back of the manifold are for water/water sensors, whatever you want.
do you have more ports than this? yellow are water, orange are vacuum.
i have a heaterhose in the front left hole and my fan switch in the rear left hole, the others are plugged
Old Jul 8, 2008 | 07:54 PM
TZFBird's Avatar
Car: 1988 Firebird, 2000 GTP
Engine: 327
Axle/Gears: 9" posi, 4.11
On my RPM Airgap, I have a port on the front crossover below the thermostat for a temp sensor/switch. The hole points forward, so I will be able to run the balance hoses front to rear and am going to put a 'T' in the left rear for the heater, which I don't use except for extra cooling capacity while cruising.
I still wish mine came with the "Made in USA" on it. Must be because it's a Vortec. That could also explain the extra port below the thermostat.
UltRoadWarrior9
Apr 28, 2020 10:39 PM
88SS6SPEED
Nov 11, 2015 07:05 AM
mrestrictrplate
Sep 21, 2015 11:24 AM
eustodp
Sep 20, 2015 05:09 PM
alpine247
Sep 16, 2015 05:25 PM
