power steering pump question
Old Jul 9, 2008 | 04:26 PM
80schild's Avatar
Car: 87 GTA
Engine: 5.7 TPI
Axle/Gears: 3:27 BW 9 bolt
Can I remove my PS pump without removing the pulley first (350 TPI)? The reason I ask is because AutoZone will pull the pulley for me if I can bring the whole thing in. I haven't torn into it yet, but I plan to tomorrow.
Old Jul 9, 2008 | 04:44 PM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Re: power steering pump question
Yes, but you have to take off the entire driver side accessory bracket, with the PS pump still attached. It's not much fun, but I've done it before. You could always rent a PS pulley puller from autozone, it makes it a lot easier.
Old Jul 9, 2008 | 04:51 PM
chesterfield's Avatar
Car: Pontiac
Also, pull out your original pressure/flow valve parts. Some of these rebuilders have a one size fits all approach to rebuilding and don't care what gm put in your pump.
Old Jul 13, 2008 | 02:47 PM
80schild's Avatar
Car: 87 GTA
Engine: 5.7 TPI
Well, I removed my PS pump (including bracket) and that part was easy, now I cant get the pulley off. I bought my new pump from Advance Auto and I rented a pulley puller but it still won't come off. I sprayed it with PB Blaster and worked with it for two hours, it won't budge . I guess I'll throw the whole thing in a box and take it to a shop for removal.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
backtothe80s
Sep 5, 2015 12:39 AM
redmaroz
Aug 16, 2015 11:40 PM
