Fuel Pump Install
Old Jul 14, 2008 | 02:18 PM
rangertough16's Avatar
Fuel Pump Install
Can anybody help me out here, changed fuel pump in my 1986 trans am, fuel pump is working, but I believe I blew the fuse when the original fuel pump died on me. Does anybody know where I can find that fuse, or the relay or any ideas on how to make the fuel pump work?
Old Jul 14, 2008 | 10:52 PM
bigbird89's Avatar
Car: 86 Firebird
Re: Fuel Pump Install
the fuel pump fuse is located in the front of the engine compartment. It's a little black plug bolted to the fender, I think it's on the pass side. (my bird has a mech. pump.) The relay is on the firewall next to the ac relay - basically a little black box on the driver's side. The relay is easy to check, it will make a relatively loud "click" when you turn the key.
Check the fuse first. If it's good, listen for the relay. If you don't hear a click, it's an easy $5 fix.
P.S. - a Haynes manual is really an indespensible tool. It's how I taught myself most of what I know...check ebay for good deals.
Good Luck!
Frozer!!!
Jan 19, 2024 04:55 PM
RazorN8
Jan 7, 2022 11:44 AM
Grant2k
Jul 10, 2018 04:01 PM
justin57
Aug 20, 2015 07:05 PM
kyleb24
Aug 15, 2015 08:24 AM
