what cam with stock heads?
Old Jul 14, 2008 | 10:45 PM
bigbird89's Avatar
Car: 86 Firebird
I'm may be getting a great deal on a fresh 305, and since it will be out of the car, I was wondering what the max cam I can run with the stock heads is. What lift will the springs handle? also, can I install 1.6 rockers, or does that depend on the cam profile?
Thanks for the help. The engine is out of an 85 Chevy truck, by the way.
Old Jul 14, 2008 | 10:57 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Re: what cam with stock heads?
Well, since we are talking about a 'not so crazy' engine you dont want to go too crazy. especially on stock heads where the valve guides are going to limit your lift.
Best bet is probably a comp XE268
It would also be nice to know the casting number of the head to confirm but i doubt you will get 1.6 rockers on it without some work.
Old Jul 14, 2008 | 11:13 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Stock springs are inadequate for a stock cam, and should be avoided like the plaque with a performance cam.
But it depends what you mean by 'work'... I had some stock 601 castings machined to handle more valve lift, and used an XE274 and it was fantastic with those heads - but you can't use a cam with that much lift w/o machining the guides. Other than that, they were stock.. as in, no port work or anything.
If you are talking totally 100% as they are shipped from GM, then I'd go no bigger than the XE262 (though thats still a pretty healthy cam). Limit the valve lift to around .460 or so with stock valve guides.
Old Jul 15, 2008 | 07:37 AM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
The 262 has a nice idle also... It's a good cam. I may be going to an xe268, though.
http://www.youtube.com/watch?v=cjXKi8dNlHE
Old Jul 15, 2008 | 06:49 PM
Air_Adam's Avatar
The XE268 is a pretty big cam for a 305, even a modified one... The XE262 is still my recommendation, its a very good cam for a 305. You have to remember, that whatever cam you use in a 305 will act about 15-20% "bigger" than the same cam in a 350, so keep that in mind.
Old Jul 15, 2008 | 07:52 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Axle/Gears: 3.43
It really depends on what hes doing with it too, he never said if he was leaving it entirely stock or if hes going to open it up a bit...
BTW, as stated in my sig, im running the 268 on 305 (406cast) heads and no clearance issues with 1.5 rockers(close, but not an issue. 1.6's wouldnt have a chance...
To be extra safe you can go with the 262 and not have to worry.
Old Jul 15, 2008 | 09:37 PM
bigbird89's Avatar
Car: 86 Firebird
I'm not too familiar with valve guides, although I'd be open to swapping some springs or getting some minor machining done. Are you referring to broze guides?
Iv'e heard alot about beehive springs, too. Would those be good with the .460 lift?
Thanks!
Old Jul 15, 2008 | 10:33 PM
SLP-GTA's Avatar
Car: 1991 Formula (sold)
Super L98 cam
http://www.tpis.com/index.php?module=2_29_08
Old Jul 15, 2008 | 10:56 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
.460 isn't enough lift to worry about beehives.
Old Jul 15, 2008 | 11:48 PM
customblackbird's Avatar
Car: 87 TA clone
Engine: 70/70 Turbo 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
why do the cam? u would get more outa a head upgrade
Old Jul 15, 2008 | 11:53 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Or the exhaust.
Old Jul 16, 2008 | 12:01 AM
Car: 87 TA clone
stock 305 heads is like sucking a basket ball through a garden hose... dont even waste ur time wit the cam unless u upgrade the heads... and yes with apeiron wit the exhaust... that should be the first modd to any 3rd gen.
also since its a truck engine... its gona be even worse wit the heads...since they will most likely flow like CR@P in the higher lift ranges since trucks need low end grunt.
Old Jul 16, 2008 | 09:26 PM
Air_Adam's Avatar
Actually, 2 of the 3 castings used on 3rdgen 305s were actually quite good heads (#416 and #081). They are commonly used on larger small blocks as budget-build performance heads, as they are as good or better than the old factory hi-perf stuff from the muscle car days. I used a set of 305 heads on my 350 and they were great, made lots of power.
Old Jul 16, 2008 | 11:01 PM
bigbird89's Avatar
Car: 86 Firebird
I plan on possibly upgrading the heads later, when I have more cash flow, and the exhaust will happen before that. I just wanted to stab a cam while the engine is out of the car. I'd like to put in the most aggressive cam that would still be driveable with the stock heads, so when I upgrade it will be a good match.
If I get the engine this weekend, I'll have more info on head castings, etc.
Old Jul 17, 2008 | 01:07 AM
Car: 1992 Camaro RS
Don't shatter his illusions!
Although, he may have a point with the mid 80s truck heads... im not sure what an 80s truck head would look like...
Old Jul 17, 2008 | 06:55 AM
327_TPI_77_Maro's Avatar
Car: 2000 BMW M5
I ran a comp DEH275 cam with mildy ported 416/081 305 heads and had no problems w/ guide clearance. The DEH275 is 0.462/0.482. This was on a 327. Turned 6500 rpms with that motor
The 416/081 heads are more than enough head for a 305. They are not the limiting factor w/ the small bore/long stroke 305. If you need more power, build a bigger engine. Spending $$$ on heads on a 305 is not cost effective, for the limited increases you'll get
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
theshackle
Mar 5, 2017 06:37 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
gta90
Sep 15, 2015 04:00 PM
camaro71633
Sep 1, 2015 10:24 AM
