crossfire injection issue
Old Jul 24, 2008 | 05:08 AM
champnesupernva's Avatar
Car: 1983 Camaro Z28
Engine: 305, holley 4bbl. stock for now
Transmission: th200c, 700r4 coming in spring
hey there. i just picked up an 83 z28 with the crossfire injection topend, sitting on the 305 bottom.
i just got the car today, and though it runs really well, there are two things besides a tune up that are bothering me.
first of all, in drive and neutral, it idles VERY high. this is my first camaro, so that could just be how they are...
secondly, as im slowing down, and the rpms are dropping (not sure of exact rpms, tach is not currently working), it kind of sputters. or moans, and then eventually gets back to steady idle.
im wondering if its a misfire, cause it does sound like its missing one in idle, ill find that out tomorrow hopefully when i install new plugs, but it has a fairly new accell distro and wires.
any help would be awesome, thanks
Old Aug 16, 2008 | 10:59 AM
Javier's Avatar
Car: 1983 Pontiac Trans Am
Engine: 5.0 Crossfire Injection
Transmission: 700 4R
Axle/Gears: 4.10
Re: crossfire injection issue
these cars need to be kept up on a monthly basis depending on how you drive check fuel pressure via the f.p. regulator mod available on crossfire injection vault, check timing replace all sensors and a tune up. should be fine after that just keep monitoring it
TheTraut88
Sep 7, 2015 05:22 PM
3tas4me
Sep 4, 2015 01:45 PM
greenyone
Sep 2, 2015 03:39 PM
3rdgenparts
Aug 6, 2015 09:03 AM
