Lifters Advertised Duration
Old Aug 4, 2008 | 01:25 PM
Rempa's Avatar
Car: 1987 IROC Z28
Engine: 305TPI
Greetings,
I have a few questions about cam and lifters:
I bought a new camshaft and some solid lifters, set it all and what happen is that my friend and greasemonkey...well...started it up without setting correctly the valve lash...now they all received a hit and they can't be used anymore, I need to unmount the camshaft to check if it was damaged...I'll buy some hydraulic flat tappet lifters but...here we are I don't know which ones to buy, I don't understand the Advertised Duration and Lift "causes and effects" so if someone could explain it to me like: larger duration means more air, means more compression for example but you'll lose some..etc..I don't understand how many differents lifters with advertised duration and lift can cost exactly the same and if it's possible, what would be a good advice for my engine or does it depends on the camshaft specs.
Thank you very much.
Old Aug 4, 2008 | 01:37 PM
formula_novice's Avatar
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
Re: Lifters Advertised Duration
You should be using hydraulic ROLLER lifters... NOT flat tappets.
This article answers some of your questions..
http://compcams.com/Community/Articl...p?ID=783188293
Hope this helps.
Old Aug 4, 2008 | 03:12 PM
Rempa's Avatar
Car: 1987 IROC Z28
Engine: 305TPI
I can't use roller lifter, my block was done for flat...I don't have the holes in the valley for the spider
Old Aug 4, 2008 | 04:17 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
More lift and more duration both mean more air (as long as you're not exceeding the flow capacity of the heads' intake ports), higher RPM operation, and less manifold vacuum. They have nothing to do with static compression ratio, and they don't have any impact on your choice of lifters.
Solid and hydraulic lifters aren't interchangeable. If your cam is designed for solid lifters, you use solid lifters. If it's designed for hydraulic lifters, you use hydraulic ones.
Old Aug 4, 2008 | 05:23 PM
Rempa's Avatar
Car: 1987 IROC Z28
Engine: 305TPI
I Have this cam installed: SB Chevy 262-400, Computer Controlled 87-98" OE Hydraulic Roller Cam, Except LT1 & LT4 - .450" Int .480" Exh lift (1000-5000)
If I'm right you can swap from roller to flat, can you? so the use of flat hydraulic lifters is possible right?
Old Aug 4, 2008 | 05:49 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
No. For that cam you must have roller lifters. If you put flat lifters on it, you'd have 16 trashed lifters and 1 trashed cam instantly.
Old Aug 4, 2008 | 08:50 PM
Rempa's Avatar
Car: 1987 IROC Z28
Engine: 305TPI
That's exactly what happened...thank you for the explanation of the reason why my face was like: "Holy mother of god...what happened..." when I saw the result of putting flat lifters on a roller cam, total disaster. I didn't know, now I do, part of the noobiness...
So in order to avoid doing something stupid: any advices on what cam+lifters kit should I buy?
http://store.summitracing.com/egnsea...115+4294887485
Thank you.
Old Aug 4, 2008 | 08:57 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
That engine needs to come apart to have all the metal that used to be the cam and lifters cleaned out of it.
Jorlain
Oct 8, 2015 01:57 AM
skinny z
Oct 5, 2015 06:23 PM
TX-SleeperC5
Sep 24, 2015 03:13 PM
dimented24x7
Sep 6, 2015 03:51 PM
