HELP
Old Aug 5, 2008 | 01:44 PM
1985transam1985's Avatar
HELP
Whenever i put my car in gear it backfires alot shuts off and wont accelerate.
Old Aug 5, 2008 | 01:45 PM
ultimatefighter's Avatar
Car: 1992 Z28
Axle/Gears: 10 bolt posi. G80
Re: HELP
What is your timing set at?
Old Aug 5, 2008 | 01:51 PM
Re: HELP
im new at this stuff and how do figur out the timing
Old Aug 5, 2008 | 02:24 PM
Randy91's Avatar
Car: 2017 Chevy Bolt
Engine: 200kw
Transmission: none
Re: HELP
Fill us in alittle. How long have you had this car? how long has it been doing this? does it do it hot, cold or both?
Old Aug 5, 2008 | 03:27 PM
Re: HELP
my dad got it in 85 and it stopped working in like 96 and we just rebuilt it and it does it all the time and when it starts up it gets hot very fast could that be a problem
Old Aug 6, 2008 | 11:54 AM
Randy91's Avatar
Engine: 200kw
Transmission: none
Re: HELP
Rebuilt what? the motor? You need a timing light to check or set the timing. What motor is in your T/A? Running hot, back firing, and dieing...I would say running very lean or timing advanced too far. Simple test for lean, with car running spray a little carb cleaner or starting fluid in the carb/throttle body, if engine picks up speed it's lean.
There is a set timing plug you need to disconnect to set the timing on this car. Sounds like you need to get a hayes or Chiltons manual to get you started.
