No Spark
Old Aug 11, 2008 | 06:58 PM
jakesTA87's Avatar
Car: 87 Trans Am
Engine: 350(5.7L)
Transmission: WC T5
Axle/Gears: Junk 2.73s
No Spark
I replaceed the coil with a Jegs performance coil and added a new set of Accel wires. Car was running great. I left to go somewhere and the car just quit around the block. I pulled a plug and there is no fire. Where do I start? Where are the fuses for the ignition? I checked the one near the battery. I dont have any testing equipment to check the voltage to the coil. Any ideas?
Old Aug 11, 2008 | 09:21 PM
jakesTA87's Avatar
Car: 87 Trans Am
Engine: 350(5.7L)
Transmission: WC T5
Re: No Spark
FIXED!!! It was the ICM. Easy fix. I took the old one to Autozone and had it tested. It was bad so I got a new one and it works fine now.
Old Aug 11, 2008 | 11:05 PM
leek157's Avatar
Car: 95 SHO. 87 IROC red 69 Vette blue
Engine: 3.0 Yamahammer.5.7 TPI L98, 350
Transmission: mtx4 ,700r4, 4speed,
Axle/Gears: 3.27, 3.73
Re: No Spark
I just had a similar problem, i checked just about everything and it still doesnt run, i started it this morning to go to work and it sounded kinda funny then just died and wouldnt start again and just kept cranking over and over
RedLeader289
May 28, 2019 01:47 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
HoosierinWA
Oct 7, 2015 10:15 AM
meeklay812
Oct 1, 2015 03:46 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
