fuel pump
Old Aug 17, 2008 | 05:36 PM
schmeck11's Avatar
Car: 82 TA
Engine: 305 swap 350 swap 383
Transmission: 2004r
Axle/Gears: 3:73
fuel pump
just put in a new engine and it came with a holley fuel pump. the old one had a return on it, this one does not. is this common, do I just plug the return or what? thanks
Old Aug 17, 2008 | 07:01 PM
TIMMYS89GTA's Avatar
Car: 81z-28,89gta,91z-28 03 1500
Engine: 355,L98vette tpi,327
Transmission: TH350/700R4/700r4/4l80E
Axle/Gears: 3;73/3;27/2;73/3;73
Re: fuel pump
mechanical fuel pump mounted on the pass. side of the block?
you running a carb?
what was prev. on the car?
Old Aug 17, 2008 | 08:42 PM
schmeck11's Avatar
Car: 82 TA
Transmission: 2004r
Axle/Gears: 3:73
Re: fuel pump
yeah, mechanical on pass. side. stock was the same way. which had a return as well.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
