TPI TO CARB, WHAT dont i NEED..HELP..
Old Aug 27, 2008 | 10:43 PM
SKYNOVERYA550's Avatar
Car: 88 iroc z28
Engine: 355
Transmission: Bowtie stg 3
Axle/Gears: 4:11
ok so im going from tpi to a carb setup. the car has everything on it, all the egr crap,a/c stuff, radiator lines all over ect..
obviously first thing is to get rid of all the tpi along with everything else that goes with it. but what else dont i need or can i take off!
ac components, heater core ect.. ect... make me a list
Old Aug 27, 2008 | 11:42 PM
doc221978's Avatar
Car: '81 Z-28
Engine: Soon to be a 383
Transmission: Muncie
Re: TPI TO CARB, WHAT dont i NEED..HELP..
All emissions can come off.
The ac and heater core can come out if you want.
All vacuum lines except to the brakes, and dizzy advance.
Fuel pump needs removed, replace with a mechanical or inline electric with regulator.
You can remove all but about half a dozen wires from the engine harness.
Using headers makes it quicker to get the smog crap off.... and makes more power then manifolds.
If it's an auto the trans lock-up will need rewired.
Cooling fans rewired.
There is probably more, you should see once you tear into it.
Old Aug 27, 2008 | 11:46 PM
irishhockey34's Avatar
Car: 92RS
Engine: LQ4
Transmission: 4L80E
kind of off topic but what are you doing with you TPI setup?
Old Aug 28, 2008 | 08:58 AM
Car: 88 iroc z28
Engine: 355
Axle/Gears: 4:11
selling everything
accel super ram plenum and runners
vortech 24lb injectors
tpis 52mm throttle body and holley 58mm throttle body
tpis big mouth base plate
mba iroc-z trim plate for both tb's
honestly i have no idea what this stuff is worth, if someone could give me a honest ball park id appriciate it!
Old Aug 28, 2008 | 12:05 PM
Car: 92RS
Engine: LQ4
Transmission: 4L80E
thats a pretty trick intake setup? why are you ditching it for a carb?
Old Aug 28, 2008 | 02:35 PM
Car: 88 iroc z28
Engine: 355
Axle/Gears: 4:11
cause im not really into tpi, more of a carb guy haha. i got the car how it is. but changing somethings around, it was the guys DD so he wanted it good on gas and cared if it passed smog, its going just to be a toy for me. not worried about smog or fuel milage.
gta90
Sep 15, 2015 04:00 PM
beachrodder
Aug 25, 2015 08:05 AM
theurge
Aug 21, 2015 12:46 PM
86IROC112
Aug 17, 2015 02:00 PM
Sanjay
Aug 12, 2015 03:41 PM
