What does this do? Under coil
Old Aug 28, 2008 | 11:51 AM
M&M_GTA88's Avatar
Car: 1988 GTA
Engine: 383 Stroker L98 TPI
Transmission: 700 R4 w/ B&M Shift Kit
Axle/Gears: Stock BW LS 9 Bolt with 3.27 gears
I needed to remove the distributor from my 88 GTA, 5.7 and came across this vacuum switch that was not connected at the electrical connection. This part sits under the remote mount coil and is attached to the same bracket as the coil. What does this do? The other side of the switch has two vacuum lines connected to it that go somewhere under the plenumn. Thanks in advance for your help.
Mike
Old Aug 28, 2008 | 02:12 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Re: What does this do? Under coil
EGR control solenoid.
Old Aug 28, 2008 | 09:30 PM
jermdm's Avatar
Car: 1989 Iroc-z
Transmission: Auto 700R4
Axle/Gears: 9 bolt - 2.77
Definitly egr solinoid. It should have 2 preformed plastic vacuum lines (which is an assembly) connected to it. 1 line goes to the egr valve itself and the other goes to a port under the driver side of throttle body
Old Nov 27, 2009 | 06:49 PM
XxodinxX's Avatar
the egr solenoid, does it have anything connecting to the back besides the plastic electrical clip?
Old Nov 28, 2009 | 02:18 PM
1991_305RS's Avatar
Car: 1991 Camaro RS
Engine: 305 TBI
Transmission: WC T-5 (slushbox)
Axle/Gears: 3.08
The OP has probably forgotten by now..
Old Nov 29, 2009 | 04:36 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Nope.
The only things are:
2 vacuum lines in the boot
1 electrical connection
The other nipple on the back USED to have a little foam filter. No need to replace it.
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
school boy
Oct 22, 2015 11:47 AM
92rsvortec350
19
Oct 9, 2015 09:39 AM
RedLeader289
Sep 23, 2015 06:50 AM
