car acting weird
Car: 89Z28 Vert
Engine: 350/tbi
Axle/Gears: 3.27 Posi
car acting weird
well i have a 91 rs 305 Tbi minor mods it has a new dizzy, coil ,sparkplugs, wires.
ok ive notice a little after warm up it feels like a miss at idle like at a stop light a good miss too but if im going steady down the road its fine then ive even notice sometimes it wont do it is this possible i still could have a faulty sparkplug even if its not consistant like that, also around 220 the car will sometimes die on me or when im going to take off from a light it will hesitate then maybe die from there or if i shut it off and try to restart its a hard start to hard to keep it running unless i ease on the gas pedal please any advice would be great oh it has a 1 yr old fuel pump as well thanks in advance
Rocky
Rocky
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
Re: car acting weird
another member just went through a similar ordeal, helped him through it and turned out fine, ill post a link to his thread, just read through it and see if your situation is the same. keep in mind that with his experience the car would jolt and jerk when the throttle was applied
https://www.thirdgen.org/forums/tech...ml#post3865451
hope it helps
hope it helps
Ghettobird52
Jul 5, 2024 11:18 PM
maroe624
Apr 16, 2017 08:29 AM
novaderrik
Aug 10, 2015 12:44 PM
