No power at AC compressor
Old Sep 2, 2008 | 03:11 PM
Sweet6's Avatar
Car: 89 Turbo Trans Am
Engine: 231 Turbo 6
Transmission: 200R
Any ideas where to look? The fuse under the dash is good. But that is only for the blower fan I believe. Let me know of good places to look.
Old Sep 2, 2008 | 04:04 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Re: No power at AC compressor
Have you tried shorting out the pressure switch? It could be low on refrigerant.
Old Sep 3, 2008 | 08:40 AM
Sweet6's Avatar
Engine: 231 Turbo 6
Transmission: 200R
Yes, I just filled it with 134. There was no power at the compressor. I checked it with a volt meter. So I am guessing bad relay/wiring. I was thinking of jumping the high and low pressure switches too. But I am open to any other suggestions.
Old Sep 3, 2008 | 09:45 PM
joeld's Avatar
Car: 1986 Firebird, 1989 Vette, 1995 GP
This might not apply to your model, but on my 86 there is a pressure switch on the power steering hose (high pressure line) that has to operate for power to reach the AC comp. My switch is very close to the steering box in the line. And I know from experience that this switch will prevent AC comp from running if faulty. Just something to check.
Joel
evilstuie
Apr 14, 2016 08:52 PM
bryanwood74
Sep 24, 2015 09:50 PM
soarestransam
Sep 1, 2015 04:00 PM
sailtexas186548
Aug 24, 2015 10:11 PM
zayne0
Aug 24, 2015 07:22 PM
