missing and sputtering
Old Sep 8, 2008 | 09:54 AM
SuperRamFormula's Avatar
Car: 87 Formula 350,11.65@122
Engine: 383,AFR Comp 195,XFI280,SRam/Mram
Transmission: T-56 Magnum-F
Axle/Gears: DANA 44 with 3.92
I have an 87 Formula 383. It is missing and sputtering intermittently. Mostly on lite accel, seems to run good at WOT. It also pops out the exhaust. It feels like secondary ignition, but I have switched out everything that could cause this. My fuel pressure is good, my timing is good. I have no codes. I have hurd that the MAF sensor can cause some pretty strange driveability concerns. I have cleaned it with MAF cleaner, but still runs poorly. I was wondering if anyone had encountered some similar problems and the MAF was the cause. Thanks
Old Sep 14, 2008 | 10:15 PM
Re: missing and sputtering
Found the problem, after starting over at square one. Found a loose electrode on one plug. Bosch +4 plugs.
Fireslash
Apr 11, 2016 06:43 PM
sammy52401
Nov 11, 2015 07:20 PM
BrianI
Oct 3, 2015 12:57 PM
Numbah-1
Oct 2, 2015 08:27 AM
lewandom
Oct 1, 2015 08:15 AM
