heads springs move on seat???
Old Sep 10, 2008 | 10:56 PM
JUNKYTRANSAM's Avatar
i just installed new springs on a set off vortec heads, i machined the spring pockets down to accept a 1.440" dual spring, i machined the valve guide and boss to accept the dual spring and a .530" valve seal, the issue im concerned with is when the springs are installed the bottoms arent centered on the shims, i can move them around by hand, never done this to heads b4, but i got em for 50$ off a 30k mile tahoe that been rearended, so i figured i'd save a little and do it my self, i had a concern with machining the pockets to far, so i cut them to 1.440 and didnt go below deck, or do i need to cut them down into the head to create a lip to hold them in place? or is this no prob at all??
Old Sep 13, 2008 | 11:07 AM
Supervisor42's Avatar
Car: 1988 Trans Am GTA
Engine: 350 4BBL
Re: heads springs move on seat???
If the guide was machined to the ID of the inner spring it will hold them centered. You should check the installed seat pressure (amount of lbs that moves the valve off the seat).
Old Sep 13, 2008 | 11:14 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Installed height should be checked but it also sounds like you need something like this
http://www.jegs.com/i/Comp%20Cams/249/4694-16/10002/-1
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
AkDrifted
Aug 17, 2015 07:45 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
