my car only starts with fuel pump not plugged in
Old Sep 17, 2008 | 03:55 PM
screamingpete87's Avatar
i have a 87 5.0tpi iroc when i plug my fuel tank in my car will not start not even a single fire when i unplug my tank the wires to the sending unit the plug under the car in front of the tank my will run at idle but obviously starves for fuel when i get the gas.
Why would plugging my fuel pump in stop the car from running?
Thanks for your help i need my baby running before snow flies and the weather is still good!!!!!!!!!
Old Sep 17, 2008 | 08:10 PM
Supervisor42's Avatar
Car: 1988 Trans Am GTA
Engine: 350 4BBL
Re: my car only starts with fuel pump not plugged in
Ruptured diaphram in fuel pressure regulator flooding the engine with gas thru the vacuum line would be one.
Shorted fuel pump drawing the voltage down and de-powering other items in the circuit would be 2.
Old Sep 17, 2008 | 09:18 PM
there is a sensor? undernieth the center of my plenum that goes into the intake with a single black wire i think it is sharting out could this cause the problem and what the **** is it? thatks for the reply ive bought a new regulator just havnt taken the old one off next project
Old Sep 17, 2008 | 09:24 PM
can i run a direct switched hot wire to my fuel pump? Do i just tap into the grey wire that goes into the fuel pump? Do i need to do a different ground i dont need my baby burning up!?
Old Sep 18, 2008 | 08:47 PM
Engine: 350 4BBL
Check out the FPR first. It's much more common.
underneath the center of my plenum that goes into the intake with a single black wire i think it is shorting out could this cause the problem
No. If so, unplugging the F/P would have no effect.
theshackle
Mar 5, 2017 06:37 PM
beachrodder
Aug 25, 2015 08:05 AM
justin57
Aug 20, 2015 07:05 PM
Kaweh
Aug 9, 2015 02:54 PM
