3 wire heated o2 wiring???
Old Sep 28, 2008 | 03:01 PM
92GTA's Avatar
I just bought a 3 wire heated Denso P/N: 234-3094. I also bought the needed pigtail GM P/N 12101923. To keep the stock o2 sensor connector on the engine harness intact, I am going to cut off the connector from the sensor I am replacing and pin that signal wire to the corresponding one on the pigtail. For the ground, I had planned on using the ground harness point on the firewall between the A/C and the distributor. It's nice and clean and easy to get to.
Where to wire up the power wire is my question. I read that someone used the pink wire at the distributor for this. I'd like to as well because it's near my planned ground and seems to make good sense.
My question is that this pink wire goes from the ignition module to the coil and into the harness, I think*. Where should I tap it exactly? Are there any other good positives I should consider tapping into that are around that area?
Also, the Denso has 1 blue wire and 2 black. The blue is on the end and the blacks are the middle and opposite side. What's what?
Thanks!
Alex
Old Sep 28, 2008 | 10:27 PM
92GTA's Avatar
Re: 3 wire heated o2 wiring???
First off, I decided it would be best to order this weatherpack adapter as it' what I was going to make anyway:
http://tpiparts.net/inc/sdetail/2167
I'll just return the pigtail I bought from GMpartsDirect or use it for something else...
After reading every single post in the search results I could find, I have decided to do what most do and wire it into the fuel pump relay.
This is the pink/black wire going into the fuel pump relay on the firewall. Any tips on how to "splice" it in?
Also I saw people asking how this will affect the voltage to the fuel pump and if WOT fuel supply will be affected but I could not find any answers. Has anyone measured the fuel pump voltage during a WOT run before and after a Ho2 install? If not, I plan to...
Thanks!
Alex
Old Sep 28, 2008 | 10:50 PM
dctrumpet's Avatar
Engine: 350 TBI W/all Ultimate TBI Mods
Transmission: 700R4 Stage 4
Axle/Gears: 9 Bolt 3.27
May i see a pic of the pigtail that you got from gmpartsdirect? If it's what i can use i may take it off your hands. How much?
Old Sep 28, 2008 | 10:58 PM
92GTA's Avatar
Sure, FedEx says it arrives Thursday. I'll snap a pic and post it in this thread and send you a PM. I paid $33.19 from GMpartsDirect and $32.55 for the one from TPIparts.net
I'd be happy to get $28 including shipping. FYI, according to GM it's the same pigtail used for the TPS sensor and a couple other sensors.
Old Sep 28, 2008 | 11:02 PM
dctrumpet's Avatar
I'll take it from you and pay what you paid for it. No need for you to loose money. I will use it soon anyway.
Your power wire needs to be connected to a + ignition switched fused 12V source. Just splice into an existing wire and use a weather tight connector/shrink connector and you'll be just fine!
Old Sep 28, 2008 | 11:13 PM
dctrumpet's Avatar
Hitting the sack. It's 11:15pm here. I will check back tomorrow.
Old Sep 30, 2008 | 03:22 PM
dctrumpet's Avatar
Let me know about the pigtail?
Old Sep 30, 2008 | 03:28 PM
92GTA's Avatar
Tracking number
364234430715295
Ship date
Sep 26, 2008
Estimated delivery
Oct 2, 2008
Lol. Don't worry, it's yours for sure. I'll open the package to post pictures then I'll just forward it to you in the same package.
Old Sep 30, 2008 | 03:40 PM
dctrumpet's Avatar
Sounds great!
Old Sep 30, 2008 | 05:03 PM
92GTA's Avatar
To get back to the topic...
I was hoping that there was a way to get the connector to the fuel pump fuse apart and for me to actually solder the Ho2 wire into it so it's clean and factory looking and a reliable connection.
Anyone done this?
Old Sep 30, 2008 | 09:21 PM
92GTA's Avatar
Problem, lol. After looking at my fuel pump relay wiring, there is no pink/black wire that I could find only the following:
Fuel pump relay :
Orange
Pink
Grey
Black w/White Stripe
Green w/White Stripe
This is of course the relay that is the passenger side of the 2 on the mount bolted to the firewall right in front of the driver.
I did notice that the drivers side most relay had the following:
Orange
Brown
Black w/Pink Stripe
But I think that is the fan relay.
There is a 3rd relay on the passenger side of the fuel pump relay but it's not on the same mount and I don't know what it is.
So which of the wires on the fuel pump relay should I wire into???!!!
Thanks!
Old Sep 30, 2008 | 09:33 PM
dctrumpet's Avatar
I have a 1992 firebird complete diagram if you are interested. It should be the same as yours.
Old Sep 30, 2008 | 09:41 PM
dctrumpet's Avatar
According to my diagram the orange is the power into the fuse and of course red from the fuse to the battery.
Old Sep 30, 2008 | 09:43 PM
92GTA's Avatar
Well I have the complete hard bound orange factory/dealer repair manual but I just can't seem to find the details on the fuel pump relay. I know I'm blind but it's kinda frustrating, lol. Nothing in the index under "Relay, Fuel Pump" or "Fuel Pump Relay" or anything like that.
EDIT: Gotcha, so the orange is the hot wire from the relay to the fuel pump?
Old Sep 30, 2008 | 09:44 PM
dctrumpet's Avatar
you'll need to dive in to the diagram and check it out. There are multiple pages associated with the fuel pump power. It depends on the year and engine, etc.
PM me your email address
what is the year and factory engine for that vehicle
Old Sep 30, 2008 | 09:51 PM
92GTA's Avatar
1992 F code, it's an LB9
PM sent...
It looks like the grey wire is the hot from the relay to the pump from what I could find in the factory manual, page 8A-22-4
Old Sep 30, 2008 | 10:12 PM
92GTA's Avatar
What about grey @ E13???
File Type: pdf
Old Sep 30, 2008 | 10:23 PM
dctrumpet's Avatar
Not sure about that one. What you need to find is the switched source. I realize you want it in a certain way, but.... LOL. You are way to much like me. I get really particular ("****") and when i get an idea i go nuts until i figure it out.
the other thing you can do it tap into the wire you suspect and test it with ignition off and then test it with ignition on and see if you found the wire/s you want.
Old Sep 30, 2008 | 10:28 PM
92GTA's Avatar
I guess I'll just grab my test probe then and check them out. I just want to be sure I get the main source of power to the pump that is NOT hot when the pump is not. I'll also be sure that it's hot when the pump is primed but not start the engine and be sure it goes dead after the pump is primed, then back on when I crank the engine. That's the winner
Thanks for the help!
Old Sep 30, 2008 | 10:30 PM
dctrumpet's Avatar
I hope that diagram helped you out! Keep me posted on here!
Old Sep 30, 2008 | 10:31 PM
92GTA's Avatar
It did, it's a much different diagram than the one in the factory manual I have.
I sure will!
Alex
Old Oct 2, 2008 | 08:45 PM
the blur's Avatar
I ran a wire back to the fuse box. and used add a fuse.
Old Oct 2, 2008 | 09:30 PM
92GTA's Avatar
dctrumpet
Can you send me your email again and I'll forward you the pics of the connector that just arrived...
Old Oct 2, 2008 | 09:33 PM
dctrumpet's Avatar
PM'd
Old Oct 2, 2008 | 09:37 PM
92GTA's Avatar
I'm going to install the sensor tonight. I use a test light/probe and some 1/2" wire loom to wrap the wires from the o2 sensor in.
I have the tool to remove the contacts from the GM weatherpack connectors so when I find the wire I'm going to use for positive, I'll pop it out of the relay connector, solder the o2 wire into it, and snap it back into the connector that plugs into the relay.
Old Oct 2, 2008 | 10:02 PM
dctrumpet's Avatar
Cool. Good luck!
Old Oct 2, 2008 | 11:33 PM
92GTA's Avatar
Ok, here are some details...
The orange wire is constant hot no matter what. The grey is in fact the one I wanted. The grey became hot when I turned the key on and the pump primed, then went dead when the pump shut off after priming with the key still on, then goes back on when the engine is started.
I took some pictures so I'll post some pictures and details/comments when I get cleaned up and relax a bit.
Old Oct 3, 2008 | 10:10 AM
92GTA's Avatar
Here are pictures of the install..
Attached Thumbnails 3 wire heated o2 wiring???-im001639.jpg   3 wire heated o2 wiring???-im001640.jpg   3 wire heated o2 wiring???-im001642.jpg   3 wire heated o2 wiring???-im001645.jpg   3 wire heated o2 wiring???-im001648.jpg
Old Oct 3, 2008 | 10:24 AM
dctrumpet's Avatar
Great job! Let me know how she runs!
Old Oct 3, 2008 | 10:30 AM
92GTA's Avatar
I HAD written a whole bunch of detailed notes between the pictures but the bloody ****-poor web server kept timing out so it lost it all. No way I'm typing it all again. The pictures can just be self explanitory. Damn I was pissed and had to walk away, ****in timeouts.
I'll let you know tonight when I retune with my notebook! I can't wait to find out either!
Old Oct 3, 2008 | 10:46 AM
dctrumpet's Avatar
Going to bank and post office right after i type this. Sending it out Priority Mail for the harness.
Old Feb 17, 2009 | 02:33 AM
The_Phoenix's Avatar
Car: Don't
Engine: have
Transmission: it
Axle/Gears: anymore
Great thread 92GTA! I'll be doing the same clean installation on my '89 GTA since its needing a new o2 sensor. Judging by the pictures, its going to be easy to install.
Thanks,
Phoenix
Old Feb 17, 2009 | 11:20 AM
92GTA's Avatar
Install did go easy, you can see in one of the pics where I put the ground. I wish it hadn't lost all of my notes.
I can honestly say that this engine has NEVER runner betterin it's life let alone in the last 9 years I've owned her! It's amazing! I did of course re-tune it after.
Old Feb 18, 2009 | 01:23 AM
Car: Don't
Engine: have
Transmission: it
Axle/Gears: anymore
Found it. Its its second to the last pic which shows you grounded it in between the firewall and the f/p, MAF, fan relay bracket correct? (hope me eyes aren't decievig me ) . I'm experiencing popping through the exhaust while in park as well as drivability is a little on the poor side. I'm more than sure it needs a new o2 sensor so while I'm at it I might as well upgrade. Can't wait to see how she runs when I get that thing installed. I'll let you know.
Later,
Phoenix
Old Feb 18, 2009 | 12:02 PM
92GTA's Avatar
You got it! Best of luck!
Old Aug 10, 2009 | 08:24 AM
cronsformula350's Avatar
Car: 89 Formula L98 power
Engine: '96 subaru, opposed 4banger
Transmission: TH700R4, subaru 4WD
Axle/Gears: 3.27, just works
I am putting a heated 3 wire o2 sensor in now, it is a bosch, but I didn't right down the part number. It has two white wires with no stripes or differences, theres no writing either. I asked one of my automotive instructors, and he said that the black is the ground, and the two white wires are the power and signal wires.
So I tried it that way, I tried to measure the output voltage of the two white wires, but they were both fluctuating about the same numbers. So I simply let the car warm up for about 18 minutes, and drove for a couple of minutes, the service engine soon light, comes on with the code for the o2 failing. I know this, because there was a bad ground wire on the passenger cylinder head. So I fixed that and the 1 wire o2 was working ok, but I know it could be better.
So I figured the two white wires, the one that set the light was the power, and the other was the signal. So I simply connected the other wire and no more engine light coming on.
But I'm starting to wonder after what someone else stated in this post. If the black wire is going to a ground, the white wire may be acting as the sensor wire, so basically like a ground, but the signal instead. And if the heated wire, the other white one is to be connected to ground, its going to back feed through the ground black wire and change the values.
What do you think guys?
Old Aug 10, 2009 | 08:31 AM
dctrumpet's Avatar
Black wire is body ground.
White wire goes to a switched/"ignition on" source and the other white wire goes to your factory purple wire.
Old Aug 10, 2009 | 08:33 AM
dctrumpet's Avatar
It could also be that it's a Bosch O2 sensor. Known for issues and failures.
Old Aug 10, 2009 | 09:11 AM
Sparkytfl's Avatar
Car: 85 TA (sold), 88 Corvette, 02 Monte
Originally Posted by cronsformula350
I am putting a heated 3 wire o2 sensor in now, it is a bosch, but I didn't right down the part number. It has two white wires with no stripes or differences, theres no writing either....
What I read was the different-colored wire is signal, and the other two are power, and it doesn't matter which of those two are pos/neg. This was just about a month ago when I installed the bosch one and it works just fine.
Old Aug 10, 2009 | 10:44 PM
I installed mine today, I ran the black wire to the stock 02 sensor pickup signal wire, and ran one white wire to ground, and the other to the fuel pump relay, the car went into closed loop within two minutes, so now I just have to see what the mileage is going to be like, I'm shooting for about 19mpg.
I got 13.5 with a messed up wire for the stock, 1 wire 02 sensor, I fixed it, and it went to about 16, but I got 22-25 in my iroc-z at
www.cardomain.com/ride/471099/8 check it out.
I am hoping for 19 mpg now, but the install was easy. There is some discrepency in the wiring, some guys say the wrong things about it, This way seems to work fine, and the way its supposed to, so yeah.
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Bryan F
Aug 27, 2015 07:28 AM
stalkier
Aug 21, 2015 01:54 AM
Rakim_RS25TH
Car Audio
Aug 20, 2015 06:22 PM
Rakim_RS25TH
Aug 18, 2015 09:32 PM
