What mods are best
What mods are best
I have an 88 camaro, IROC-Z. I purchased it from a private owner about 2 months ago and i want to know how i can boost my performance most efficiently. It has just under 90K miles and already has headers, a flow master exhaust, and i suspect it has a high perfomance cam and a shift kit. The exhaust however is a single pipe coming from my headers and also sags low, causing scraping at times. So a new exhaust system would be an option. Any new mods that are not too expensive but efficient are what i am looking for. I have thought about maybe chipping it and fitting a CAI for it.
Car: 92' firebird
Axle/Gears: 10 bolt POSI 3.73's
Re: What mods are best
Get some tunning equipment and do lots of reading. Tunning can be fun with all the info on TGO.
If I had to mod my car all over agian I would start with tunning I love my EBL--
www.dynamicefi.com
www.dynamicefi.com
Car: Firechicken
Engine: 350 + 30 over, 400 crank
Transmission: autotragic, stalled
Axle/Gears: not a one tire fire, thank god!
You will love doing the suspension! It will handle and grab like nothing you've felt before. Only grandma hugs tighter than Spohn suspension.
Car: 1984 Firebird SE
Engine: 388 sbc, Brodix Track 1s
Transmission: turbo 350 transmission
Axle/Gears: 4.10 gears
I would definitely start with suspension mods. Also replace the sway bar, torque arms bushings with polyurethane.
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
well just my
make sure its roadworthy . tires , brakes , lights etc. . then intake , exhaust ( nothing wrong with flowmaster , i'm sure it can be tucked up closer ) . then ignition ( i like M.S.D. because i have used them for years with good results and perfomance ) . others are also good . A.C. plugs are hard to beat . then suspension , with normal operation o.e.m. stuff is o.k. . if your going to race of any type or kind then ck. poly bushings and struts . o.e.m. stuff is better than most people give credit . good luck , have fun .
make sure its roadworthy . tires , brakes , lights etc. . then intake , exhaust ( nothing wrong with flowmaster , i'm sure it can be tucked up closer ) . then ignition ( i like M.S.D. because i have used them for years with good results and perfomance ) . others are also good . A.C. plugs are hard to beat . then suspension , with normal operation o.e.m. stuff is o.k. . if your going to race of any type or kind then ck. poly bushings and struts . o.e.m. stuff is better than most people give credit . good luck , have fun . Thread
