355 to 383
Old Sep 30, 2008 | 03:13 PM
bummys_hotrod's Avatar
Car: 84 Z28
Engine: 383
Axle/Gears: 7.5 3.73
355 to 383
I have looked everywhere on the internet and this site to try to find what all you need extra to convert a 355 to a 383 stroker. Can someone tell me, I know you have to get the block machined for clearance of the crank. Is that the only difference is the crank and mabye a bigger cam? Any advice would be appriciated.
Old Sep 30, 2008 | 04:45 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Re: 355 to 383
Just strictly to change from a 355 to 383, you need a new crank and pistons, if you want the short list. If its a 355, the block's already been bored .030" as a 383 would be. You'd also need all the bearings, hardware, gaskets, etc that one would need to do a basic bottom end rebuild as well.
Old Sep 30, 2008 | 07:09 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: 355 to 383
A new crank and one of new pistons or new rods. No machining of the block is required beyond what it ordinarily needs for a rebuild. Clearancing the block is a manual operation that can be done by hand with a die grinder.
darwinprice
17
Oct 11, 2015 11:51 PM
LT1Formula
Oct 8, 2015 08:34 PM
