DYNO!!
Old Oct 8, 2008 | 10:19 AM
roughskinjrz's Avatar
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
DYNO!!
DYNO TOMORROW!!!
any guesses what it will produce? before i post the dyno sheet and pics? complete specs are:
454 2 bolt GM block
eagle 4.250" steel crank
eagle forged 6.385" rods
srp forged 4.280 flat top pistons
crane z 244/256 .632/.632 114 blower cam
procomp 320 cc heads (titanium retainers, matching springs, manley severe duty valvs)
comp cam hi tech 1.8 roller rockers
weiand 871 blower 7-8lbs
2 x 800cfm barry grant blower carbs
csr electric water pump
gm 100amp alternator
hooker super comp 2" headers
Old Oct 8, 2008 | 11:34 AM
fast82z's Avatar
Car: 82 Z28
Engine: TT LS
Transmission: 4L80E
Axle/Gears: S60 3.54's
Re: DYNO!!
I'm guessing something close to 625rwhp, but I could be way off as I only really know small block stuff well. Seems like the trans/converter can really vary the dyno a ton also.
Old Oct 8, 2008 | 01:45 PM
MaxxMitchell's Avatar
Car: 87 Firebird
Engine: 5.3 76mm
Transmission: Rossler TH400, PTC converter
Axle/Gears: Strange 12bolt, 3.08s
Re: DYNO!!
550rwhp/600rwtq?
Im not real familar with BBC and power numbers either. Has it seen the track yet?
Either way, Im sure its fun to take down the track, or drive around.
Old Oct 16, 2008 | 10:20 PM
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
Re: DYNO!!
it was an engine dyno and it made 815 horsepower @ 6200rpm and 742ft lbs tq @ 4900rpm.
i had to change from 1.8 rockers to 1.7 rockers because there was valve float from too much spring pressure. the blower backfired pretty hard, lol.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
darwinprice
17
Oct 11, 2015 11:51 PM
Nervous2
Oct 8, 2015 10:53 PM
LT1Formula
Oct 8, 2015 08:34 PM
BBSDesigns
Sep 22, 2015 03:08 PM
