fuel pump relay "83 firebird"
Subscribe
Oct 10, 2008 | 03:58 AM
any ideas of how to bypass fuel pump relay to make sure the fuel pump is working. i done it to my chevy truck, but dont know where the the wire to bypass the relay is located on my trans am. i know i should try to hear for humming sound ,but since i dont have anyone to turn the key for me, and i cant hear from inside the car. thanks
Reply 0
Oct 10, 2008 | 06:53 AM
Re: fuel pump relay "83 firebird"
I will look in my service manual if I can free up some time this afternoon...
also, try rolling the window down and standing outside the car to listen for the humming sound... thats what I have to do...
Reply 0
Oct 10, 2008 | 07:17 AM
Terminal "G" of the OBD1 connector.
Reply 0
Oct 11, 2008 | 06:09 AM
rgarcia can u tell me whre the obd1 is located and can u draw a pic for me. thanks
Reply 0
Oct 11, 2008 | 11:17 AM
It's described in the Tech FAQ link from the thirdgen.org home page.
If you search the forum for "ALDL", you'll find pictures (from Vader if memory serves).
Reply 0
Oct 11, 2008 | 12:27 PM
tino is your car CFI or carbed? if carbed, you may only have a mechanical pump
Reply 0
Oct 11, 2008 | 04:50 PM
On this website http://theking.joakimweb.se/z28/felkoder.htm there's an image of a dash and just below it is an ALDL diagram. Apply 12volts to the "G" terminal. This is a great way to drain the tank.
Reply 0
Oct 11, 2008 | 05:31 PM
Quote: rgarcia can u tell me whre the obd1 is located and can u draw a pic for me. thanks
Under dash just in front of your right knee.
Reply 0
Oct 11, 2008 | 05:43 PM
On my CFI car I just jumped from the orange wire on one side on the connector to the red wire connector on the other side of the relay. pump came on right away. In fact that is how my pump is set up now with the orange wire wired to a ignition hot and the red pump power wire wired to the orange wire.
Reply 0
Subscribe
