Map Sensor
Old Oct 26, 2008 | 07:39 PM
one2burn's Avatar
Map Sensor
Does anyone out there know if my map sensor can be the sole cause of not being able to accelerate causing the engine to bog and try to die. I have went through most every thing you can check and replaced Ing. mod. cap rotor wires plugs and TPS even found my ESC wire discon. and reattached yet all still the same. I guess Im hoping to here someone with same prob. that had sucess with its replacement. Thanks for any help, George.
Old Oct 26, 2008 | 08:57 PM
black3rdgen's Avatar
Car: 84z28
Re: Map Sensor
yep sure can. Ive had a vacuum line that connects to it melt and cause the car to completly run like ****. fixed the line and ran like new. I pulled the codes for this.
Old Oct 27, 2008 | 02:23 PM
one2burn's Avatar
Re: Map Sensor
Hi. I guess in then by what you are saying that even though my hose is ok and it is getting vacume ok ( checked and all ok ) that a failure of that unit can cause the boging issue and replacing it can possibly stop my problem. I hope. Thanks again, George.
meeklay812
Oct 1, 2015 03:46 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
dusterbd
Sep 29, 2015 08:40 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
efiguy
Sep 27, 2015 01:30 PM
