i have a question on heads i should go with.
Old Oct 28, 2008 | 11:44 PM
jakemk8706's Avatar
Car: 1991 Z28 Camaro
Transmission: WC-T5
hi, i have been a member of tgo for over a year now but this is my first time posting.
for starters i have a 91 Z28 camaro with the 305 tpi t-5 combo. it is fairly stock for now.
right now i am in the process of building a 350 to replace the 305. it is my first motor build so i am not trying to go over the top with power or top of the line parts i just want to get a motor build under my belt before i go all out.
the deal is i already have a set of "462" heads. i believe those have 2.02 and 1.6. so for a christmas gift my dad got me this cam package
http://store.summitracing.com/partde...2&autoview=sku
he was told this would work well with those heads.
recently i acquired a set of alluminum corvette heads. i think # "141" or something. so i was wondering which heads would work better with this motor. i know that my stock intake manifold will not match up with the perimeter style heads but i wasnt planning on keeping the stock tpi. i want hsr, but im not sure if holley makes a hsr that will work with older heads.
so which do you guys think i should go with???
Old Oct 29, 2008 | 08:36 AM
formula_novice's Avatar
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
Re: i have a question on heads i should go with.
If your motor is a roller block, that cam will not work. It is a Hydraulic flat tappet cam and you need a Hydraulic ROLLER cam.
Old Oct 29, 2008 | 09:56 AM
jakemk8706's Avatar
Transmission: WC-T5
the 350 block that i have is not a ROLLER block.
Old Oct 29, 2008 | 04:52 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
If it was my project, I'd use the aluminum heads.
MustangBeater20
Oct 29, 2022 09:20 PM
Mickeyruder
Sep 2, 2015 02:45 PM
NinjaNife
Aug 23, 2015 11:49 AM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
