1991 RS V6 Won't Start Cold - Starts Hot
Old Nov 4, 2008 | 09:30 PM
one2burn's Avatar
Can this be a Ing. Coil causing this, hard starting cold but once you get it started and warm it starts ok, I've been suffering a stalling problem also when cracking the throttle.
Old Nov 4, 2008 | 09:36 PM
kcb37's Avatar
Re: 1991 RS V6 Won't Start Cold - Starts Hot
Do you have an engine light?
Do you have fuel and spark when it's cold?
A thought would be the CTS thinking it's extremely cold and flooding it.
Wouldn't hurt to check your timing.
I would also clean the IAC and check the TPS.
Old Nov 4, 2008 | 09:49 PM
one2burn's Avatar
No codes no lights fuel psi ok don't think its flooding dont smell a lot of gas pulled plug not wet timing ok iac works well high idle cold and drops down ok cts could be the problem when idle finaly drops after iac radaitor fan kicks on but still have stalling prob. when cracking throttle idles fine
Linson
Oct 24, 2025 02:00 PM
FormulasOnly
Jul 23, 2018 08:47 AM
blackz281le
Jan 11, 2016 07:51 AM
Jlanz55
Sep 29, 2015 08:55 AM
amcnellis
Sep 16, 2015 04:16 PM
