Barely starts
Old Nov 5, 2008 | 07:22 PM
foxypops's Avatar
Car: 1986 Iroc Z28
Barely starts
Just purchased a 1986 Trans Am with a 305 TPI. Doesn't really run. Tries to start and when it does it wont accelerate. Just a rough Idle. Any thoughts?
Old Nov 5, 2008 | 07:55 PM
85z28nb's Avatar
Car: 85 camaro z28
Engine: 305 but i got a '70 350 LT1
Axle/Gears: 3.08
Re: Barely starts
has the car had a tune up recently?
Old Nov 5, 2008 | 09:03 PM
jbates346's Avatar
Re: Barely starts
I would check the fuel pressure. Next i would spray starting fluid/carb cleaner into the intake and see if the idle changes. If it does obviously your not getting fuel. The fun part would be figuring out why.
Old Nov 6, 2008 | 03:53 AM
Tranquil's Avatar
Re: Barely starts
Fuel pressure is first. Jbates has the best suggestion, ether spray (starting fluid) may even your idle out. If that's the case, then you're not getting enough fuel. Second off, I'd do a tuneup. Plugs, wires, distributor cap, rotor, and of course an oil change. If it's a very slow turn when you're trying to start it, take your starter off and take it over to autozone to get it tested. It's free.
After you do all of that (Actually, after you test your fuel pressure) and it's still acting up, I'd do a few things
1) Seafoam the hell out of it. Gas tank, intake, oil pan (But change your oil shortly after, maybe 300 miles) - You'd be suprised how big of a difference that can make.
2) Gaskets. Take your top end apart, chances are they are all shot. Intake gasket, thermostat housing gasket (if you have a chrome thermostat housing change it asap! They have caused me nothing but trouble) valve cover gaskets, distributor gasket.
My .02$. If anyone disagrees, feel free to call me out.
92camaroJoe
Jul 29, 2023 07:57 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
perZ
Aug 21, 2015 05:51 PM
92camaroJoe
Aug 13, 2015 06:07 AM
