replaced gas tank, starts, runs, runs out of gas
Old Nov 17, 2008 | 07:56 PM
camarodubs's Avatar
Car: 1987 camaro
Engine: gm goodwrench crate 350 mild
Axle/Gears: 28 spline 7.625 10 bolt w/273
i replaced my gas tank, original was leaking. now the engine starts and runs good, but after driving a few miles under demand it stalls and starves of fuel. i have to give it a few minutes pump and crank a while and it will run good untill it starves of gass again.
Old Nov 17, 2008 | 09:06 PM
drknow90rs_ss@y's Avatar
Car: 86 IROC-Z, '71 RS
Engine: 305 TPI/ 350
Transmission: 700R4/TH350
Re: replaced gas tank, starts, runs, runs out of gas
You didnt say which fuel system you have...(TPI, carb, TBI...) I'm gonna take a stab and say you have a fuel inj setup. Did you also replace the sending unit/fuel pump setup? There is a rubber hose on the sender that attaches the fuel pump to the hard line. If this is broken/cracked it will not allow fuel pressure to build and will starve the injectors.
When you first turn the key on (One click before "crank" position) You should hear the fuel pump "Prime" after a second or two this should go quiet. If it does not then you have a pressure problem.
Let us know.
Old Nov 18, 2008 | 09:14 AM
OldCelica's Avatar
Car: '91 Camaro 305V8, '91 Camaro 3.1V6
Was there a baffle in the new tank?
Old Nov 19, 2008 | 01:12 PM
camarodubs's Avatar
Car: 1987 camaro
yes there was a baffle and it is carburated with mech fuel pump
Frozer!!!
Jan 19, 2024 04:55 PM
mustangman65_79
Sep 1, 2015 03:51 PM
AkDrifted
Aug 17, 2015 07:45 PM
kyleb24
Aug 15, 2015 08:24 AM
mizz0313
Aug 12, 2015 06:45 AM
