stall speed worksheet?
Old Nov 23, 2008 | 06:11 PM
irocinblue89's Avatar
Car: 89 iroc
Engine: zz383/compcam/gmpp intake/holley770
Transmission: 700r4 w/all the goodies
Axle/Gears: 4th gen 3:23w/powertrax
I would like to know if there is a website that can recommend the correct stall speed. Or maybe I could get some ideas from all of you. I am ordering Monday from atechmotorsports. Thanks in advance!
Car specs: 89 iroc, 700r4, 2001 10 bolt w/3:23, stock rims and tires
Engine Specifications and Features:
  • Horsepower: 425 @ 5400 & Torque: 460 @ 4500
  • Max. Recommended RPM: 6000
  • 9.6:1 Compression Ratio
  • 4340 Crankshaft: Forged Steel
  • HD PM Connecting Rods GM#10108688
  • Camshaft 12370846 (hydraulic roller): -Gross Lift (.509 I / .528 E.) -Duration @ .050 (222 I / 230 E).
  • GM Fast Burn 12464298 aluminum heads w/62cc. combustion chambers.
  • Rockers: 1.5:1 Roller Rocker
  • Cast iron 4 bolt main block
  • 8” GM Performance Balancer
  • GM aluminum single-plane intake manifold.
  • GMPP/Holley 750CFM Carb w/vac secondaries
  • GM Performance curve HEI distributor.
  • GM Performance Plug wires
  • GM Performance fuel pump (plumbed pump to carb)
  • GM Performance High Torque Starter
  • 12.75” A/T Flywheel
  • Chevy Fabricated Aluminum Valve Covers & Air Cleaner
Old Nov 23, 2008 | 06:29 PM
Car: 89 iroc
Re: stall speed worksheet?
i am really sorry for putting it in the wrong section! I will repost in tranny tech.
Old Nov 24, 2008 | 12:29 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Since it's still here, and since I found it here, here's my take:
If you're gonna run a dual plane, and drive it every day, try a stall about 500 rpm over stock, like B&M's Holeshot 2000. If you wanna get wild, a 2400-2500 wouls do. Using a 2800 or higher is wasting all that this stroker has to offer.
Hotrodboba400
Dec 10, 2019 07:07 PM
rjcme
Sep 5, 2015 01:23 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
