gta not starting
Old Dec 6, 2008 | 04:03 PM
formula forever's Avatar
Car: 91 formula
Engine: 350 tuned port. bolt ons
gta not starting
went out today car will not even crank or turnover. when i turned the key just a starter solinoid click. one click. my light work fine and all power i have. battery looks good and battery cables are tight. If i turn on the lights and power and try to turn it over the lights stay on and will not dime.
Old Dec 6, 2008 | 04:15 PM
1piece@atime's Avatar
Car: 86 T/A
Engine: 5.0 TPI
Re: gta not starting
Reach down and turn the engine a little by the fanbelt or put a socket on the crank bolt. Then give it another try. The starter may be stuck between gears.
Old Dec 6, 2008 | 04:51 PM
tom86iroc's Avatar
Car: 1986 iroc
Engine: alum. head 350 supercharged
Transmission: 6speed
Axle/Gears: ford 9in 3.90 35 spline moser axles
have someone hold the key and tap the starter with a hammer usually frees it up starters on the way out it seems like
Old Dec 8, 2008 | 04:19 PM
skate4music's Avatar
Have you tried starting it recently? My car is doing what sounds like the same or a similar thing. Mine will sometimes not start. I believe I have a problem with the anti theft system. Sometimes when I go to start the car I get nothing at all from the engine but all of the lights and gauges work. If I then wait about 4 minutes and try again it starts. It also is giving me a code 53 which deals with the theft system.
Old Dec 8, 2008 | 10:57 PM
Car: 91 formula
well i found out the cold weather killed my old starter. I had too move my y-pipe out of the way just to get the starter out
bryan623
Mar 22, 2021 06:43 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
The_Phoenix
Feb 4, 2016 07:10 AM
Winchester1094
Aug 18, 2015 10:23 AM
Street Lethal
Aug 14, 2015 08:25 PM
