400sb 426 stroker kit
Anyone ever heard of this kit? A friend of mine who's a killer mechanic told me about this kit. It consists of an offset crank, and small journal 327 rods. IF anyone can point me where to look it would be appreciated. Btw the 400 in question will be going into a 1985 Firebird.
Transmission: 4L80E/4L80E
Welcome aboard thirdgen.org.
I haven't heard of any kit with those specifics.
Car: A Portly 85 Z28
Engine: 4.530 X 4.250 BBC
Transmission: under rated for this application
Axle/Gears: also under rated
Re: 400sb 426 stroker kit
Yea, I recall a kit that used an offset ground crank and 327 rods (small journal) it was a 415 cid though
On Probation
Engine: several
Transmission: none
Axle/Gears: none
If you have a 400 block, assuming you bore it +0.030" a 4" stroke will go in just fine and get you 434 ci.
If you're trying to get 426 from a 350, it's not happening. A 4.060" bore and a 4" stroke will get you 414.3 ci.
To use any more stroke requires a non-production tall-deck block with a raised cam tunnel and spread oilpan rails. This in turn requires a different timing set, oilpan, and intake manifold spacers.
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
