no power to starter
Old Dec 16, 2008 | 01:13 AM
skills287's Avatar
no power to starter
i cant figure out why i cant get any power to my starter its a 1992 camaro rs bone stock and just cant figure it out any tips on how to fix this this is my daily driver
Old Dec 16, 2008 | 01:18 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Re: no power to starter
There's 2 power supplies to the starter solenoid: constant hot from the battery, and the ignition switch. Which isn't going hot?
Old Dec 16, 2008 | 01:25 AM
skills287's Avatar
well from the bat is hot but from the key it isnt doing anything
Old Dec 16, 2008 | 05:18 AM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
The ignition always hot feed is from the starter through a fusible link connection where the battery cable connects at the starter.
There are 3 fusible links at the starter only one of these has 2 red wires that is the one you need to check. Otherwise you have a break in the ignition wire.
post back if you need more help.
BRoss99
Aug 10, 2025 05:08 PM
5spdcamaro
Aug 28, 2015 02:12 AM
L98GTA87
Aug 25, 2015 02:23 PM
sailtexas186548
Aug 24, 2015 10:11 PM
Accerrito22
Aug 23, 2015 07:22 PM
