Help fuel pump
Old Dec 20, 2008 | 03:57 AM
TazCowboy's Avatar
Car: 1991 Camaro RS
Engine: 350 SBC
Help fuel pump
I removed the electric pump since I went to a carb 350 However its not getting fuel to the manual pump. the lines are clear I blew air through it with air compressor. Im thinking the battery might be a slight problem since it cranks a few seconds then doesnt have enough juice. but ya would think it would get fuel sooner or later right?
Old Dec 20, 2008 | 08:41 AM
sgreen3's Avatar
Car: 1984 Z28
Engine: 355ci
Transmission: WC T-5 (untill it breaks)
Axle/Gears: 3.73 Posi
Re: Help fuel pump
Im assuming that you removed the intank pump from the assembly? If so sometimes it can be a little hard to get a mechanical pump to prime. but you should have installed some sort of pick-up hose or tube were the electric pump was. You could either blow compressed air into the filler neck or you may have to get a small in-line electric pump to use a a pusher.
hope this helps
Old Dec 23, 2008 | 11:48 AM
blp226's Avatar
Re: Help fuel pump
I had the exact same problem. You have to install an electric back by the tank as well as your manual one. I did that and haven't had a problem since.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
