starting issues
Old Dec 29, 2008 | 07:54 PM
3rdgenZ's Avatar
Car: 1985 Z28
Engine: 85 L98
Axle/Gears: stock 10 bolt-3.73 eaten posi
starting issues
okay, here is the deal. iam helping a friend with a carb swap. weve got the motor in and it runs great, but after the engine gets hot after running around it will not turn over. ( once you kill it after getting hot it will not turn over).
if the engine is cold it turns over easy. the battery stays at about 13.5v.
(after getting hot) if you turn the starter over it goes from 13.5v to 4.5v
battery and the altenator are new.
could this just be a bad starter???
Old Dec 29, 2008 | 09:39 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Re: starting issues
Is it a factory starter? If so, the factory direct drive units aren't exactly known for being the best in the world at hot starting. Might be time for a good gear reduction starter.
Frozer!!!
Jan 19, 2024 04:55 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Bryan F
Aug 18, 2015 02:28 PM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
86Base
Aug 8, 2015 01:34 PM
