how do you test injectors?
Old Jan 1, 2009 | 01:19 PM
mfaust's Avatar
Car: 88' Trans-AM WS6
I need to test to see if the injectors are spraying, How is this done?
Old Jan 1, 2009 | 05:34 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Re: how do you test injectors?
I take some fuel line, clamp one end on the injector, fill the line with gas or solvent, connect the other end to my compressor and set it for 35 psi. Then I hold the injector in a 2K Coke bottle and open it with 12V across the terminals.
You can see the pattern and any leaks.
Of course you need to be very careful with gas and electricity, especially in an enclosed area.
Old Jan 4, 2009 | 06:20 PM
Gibson27's Avatar
Car: 84 z28
Engine: 383 stroker
Transmission: th-350
Axle/Gears: 3:42
or there may be a electrical issue, then noid lights would be handy.
Old Jan 12, 2009 | 09:33 AM
sgreen3's Avatar
Car: 1984 Z28
Engine: 355ci
Transmission: WC T-5 (untill it breaks)
Axle/Gears: 3.73 Posi
you can use a DVOM and test the resitance of the injector.
92projectcamaro
Jan 18, 2016 08:00 AM
BAMiller
Sep 14, 2015 06:38 PM
greenyone
Sep 2, 2015 03:39 PM
Jae992
Aug 27, 2015 09:07 AM
