help with initial timing after carb swap
Old Jan 4, 2009 | 01:06 PM
buzzman1's Avatar
Car: 90 formula
Engine: 305 carb
Axle/Gears: auburn 3.73 posi
swapped a holley carb for tbi and am running a vac advance msd dist and ignition box (summit brand). I am trying to get an idea where to set the timing at idle to get the motor started and idleing. non stock cam, headers.
thanks in advance for any help.
Buzzman1
Old Jan 4, 2009 | 03:04 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: help with initial timing after carb swap
Anything before 0 will be enough to get it to start.
Old Jan 4, 2009 | 03:08 PM
buzzman1's Avatar
Car: 90 formula
Engine: 305 carb
thanks..Ill try 0 first...again thanks for the help
Buzzman1
theshackle
Sep 17, 2020 08:26 AM
midge54
Dec 27, 2019 04:14 PM
theshackle
Mar 5, 2017 06:37 PM
midge54
Jan 29, 2017 07:00 PM
bellez77
Sep 5, 2015 08:39 PM
