Quick Question... I am stumped
Old Jan 5, 2009 | 06:34 AM
deoverton's Avatar
Car: 1992 Camaro RS
Ok so last night I go to get into my car and turn the ignition it doesnt even turn over. From there I start looking at everything... I have full power and the car has been running and starting fine. I pop the hood and take a look at the battery cable and they are both tight. I move the shifter from park down to 1st and back to park and try it again...nothing. Finally I got mad shut the hood and gave it one more try. Then it decides to fire up like brand new.
Anyone have any idea or previous experience with something like this cause I am stumped.
Old Jan 5, 2009 | 06:56 AM
AC's Avatar
AC
Car: Used to drive a camaro
Re: Quick Question... I am stumped
When you tried to start it and it didn't turn over, did you hear a click atleast or several clicks? I'm leaning towards the starter solenoid.
Old Jan 5, 2009 | 07:45 AM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
could be the wiring in the tilt steering column
next time it wont start try moving the tilt
if that does not work then use a test light and put it on the s terminal on the starter with the purple wire
have someone turn the key and the test light should light up. if not replace the seliniod or better yet the whole starter because sbc starters are super cheap
Old Jan 5, 2009 | 02:05 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
*cough* vats...*cough*
Mine did it too, lots of times, no rhyme or reason for it but it just happened, been trouble free since i bypassed it lol
F-body-fan
Jan 12, 2023 01:49 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
meeklay812
Oct 1, 2015 03:46 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
3.8TransAM
Sep 27, 2015 08:37 PM
