Fuel Feed line
Old Jan 9, 2009 | 10:01 PM
Gladstoneiroc's Avatar
Car: 91 Camaro RS
Engine: 5.0L TBI (ebl inside)
Axle/Gears: 3.42 lsd 10 bolt
Fuel Feed line
Does anyone have the part number for the rubber/metal feed line that runs from the fuel pump to the fuel filter? Also availability?
Old Jan 9, 2009 | 10:09 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Fuel Feed line
There isn't a part number, GM serviced it with bulk tubing bent to fit.
Old Jan 10, 2009 | 08:43 AM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Re: Fuel Feed line
Someone (Dorman I think) makes a repair kit that Advance sells. It's couple feet of tubing with the right fitting for the filter and a brass compression fitting.
theshackle
Mar 5, 2017 06:37 PM
beachrodder
Aug 25, 2015 08:05 AM
AkDrifted
Aug 17, 2015 07:45 PM
armybyrd
Aug 10, 2015 09:23 PM
Kaweh
Aug 9, 2015 02:54 PM
