Take a look
Old Jan 11, 2009 | 03:47 PM
1986Z28OWNER's Avatar
Car: 1979 Malibu
Engine: Blown LSx
Transmission: T56 Magnum
Axle/Gears: 9"/wavetrac/35's/3.70
Take a look
Just wanted some of your honest opinions on my combo for a engine im currently building, here are some specs:
-Vortec "880" block machined 0.030" over, tanked, magnafluxed, decked approx 0.010"
-Eagle 355ci balanced rotating assemblie, Cast crank, I-beam rods, KB hyp flat top pistons, approx 10.0:1 compression
-Comp cams 08-433-8 hydraulic roller camshaft, 0.520/0.540 lift, 110 LSA, 236/242 duration @ 0.050"
-World products Sportsman II heads, 986-16 springs, 64cc chambers, angle plugs
-Comp cams 1.52 pro magnum rocker arms
-Edelbrock performer RPM airgap intake
-Full MSD ignition
-Holley 700DP carb
from what i can figure, this combo should be good in the area of 425hp at the crank, what do you guys think?
Old Jan 11, 2009 | 08:11 PM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
Re: Take a look
dude you know what its gonna make
do you want a thumbs up or a pat on the back
build it for yourself
not to impress us
Old Jan 11, 2009 | 08:32 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Take a look
What rods are you going to use?
Old Jan 11, 2009 | 08:45 PM
Car: 1979 Malibu
Engine: Blown LSx
Re: Take a look
eagle I-beams that came with the rotating assemblie, i had the machine shop check em out(ive heard of some issues with there I-beams) but they said they checked out just fine
Old Jan 11, 2009 | 08:49 PM
creese187's Avatar
Re: Take a look
i dont know what kind of car you are putting this in, but if your putting it in a thirdgen camaro/firebird, then you most likely are going to use shorty headers, and shorty headers will not clear your angled plug heads, believe me i made this mistake, you need to get straight plugs, just like the original L98 head, that is if you are using shorties and you do have a thirdgen chassis
Old Jan 11, 2009 | 09:33 PM
Car: 1979 Malibu
Engine: Blown LSx
Re: Take a look
Hooker 2460's CLEARLY state they will work with angle plug heads, ive gone through this already. the heads came off another thirdgen, and ive mached up the headers to the heads already, with no clearance issues
