Old AFR 195cc heads installed height??
Old Jan 12, 2009 | 05:05 PM
89formula350b2l's Avatar
Car: 92 Camaro
Engine: Dart SHP 406 HSR, LE heads
Transmission: Performabuilt Level 2, Vig 3200
Axle/Gears: S60 373
i am currently in iraq right now and i cannot measure this right now. i need to order new springs and need to know at what height. Remember, these are NOT the Eliminator series.
Old Jan 12, 2009 | 05:06 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Old AFR 195cc heads installed height??
You assemble them to whatever height the springs want.
Old Jan 12, 2009 | 06:35 PM
Car: 92 Camaro
Axle/Gears: S60 373
So if i use ISK-8005-A everything should be ok?? what else should i replace? which retainers should i also use?
customblackbird
Aug 15, 2021 10:16 PM
evilstuie
Jan 9, 2020 08:29 PM
CRFred
Feb 7, 2016 11:39 PM
89mulletbird
Aug 12, 2015 07:08 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
