Debating major changes
Old Jan 13, 2009 | 04:35 PM
blg0720's Avatar
Car: 88 GTA
Engine: 305 V8 LB9
Transmission: 4 sp. Auto-4L60
Once I get the know-how, I'm debating some major changes. Right now, I have the Edelbrock carb and intake. Okay, fine...it works. I'm debating, however, going back to a stock carbed engine. With me so far?
Here's the catch.
My TA was originally a Crossfire. I have the dual mufflers, and that's the only reason I know that. That I do NOT want to go back to. BUT, I'm thinking I might take it back to a stock 305. I have NO intention of swapping, but I want to get all the power I can out of the original motor without compromising what's in there.
WWYD, and HOW?
Old Jan 13, 2009 | 04:51 PM
hotrod7687's Avatar
Car: '91 Camaro, 90 Formula
Engine: 355 carb, 305 TPI
Transmission: TH 350, 700R4
Re: Debating major changes
So what you're saying is that you have a 305 in there now with an edelbrock carb and intake and you want to go back with a stock intake and carb?
If you want to get the best performance out of the engine that would be a bad idea. The edelbrock carb and intake will be better than a stock intake, and probably give better gas mileage too if its tuned right.
Going back to factory anything once you have aftermarket parts will only hurt performance.
If you want to get more performance without going into the engine I would keep the intake and carb, go with a full exhaust from headers all the way back to the tailpipes, a good MSD or Accel distributor and set of plug wires.
That should give you a nice bump in power without touching any of the engine internals, and if tuned right will be just as reliable as factory.
Old Jan 13, 2009 | 06:04 PM
blg0720's Avatar
Car: 88 GTA
Engine: 305 V8 LB9
My hesitation with headers is that I HATE how noisy they are. I love that low, throaty purr I get now. How can I keep that and still improve performance?
Old Jan 13, 2009 | 06:12 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
If you have straight log manifolds now you could swap to corvette or LT1 exhaust manifolds & then get a performance Y-pipe to fit that and a normal cat-back system.
Old Jan 13, 2009 | 06:20 PM
blg0720's Avatar
Car: 88 GTA
Engine: 305 V8 LB9
I'll see if I can grab some pictures tomorrow when it's light out. Seriously, under the hood, I know ZIP, or next to it...I DO know that the exhaust on it now, with the exception of the cat, is the original exhaust. Amazing, I know...but it is. The cat is new, but only because I couldn't pass a "Tampering" inspection without having one... ...or so I was told. And the "previous owner" got rid of the cat and welded the tailpipe straight on.
Old Jan 13, 2009 | 06:30 PM
hotrod7687's Avatar
If you dont change any of the rest of the exhaust, then the headers by themselves wont make it much louder.
Headers combined with a free flowing cat and an aggressive muffler will make your car quite a but louder. You do have some options for a quiet muffler that flows reasonably well. A full exhaust system with a flowmaster 30 series wouldnt be extremely loud.
ZZ3Astro
Aug 13, 2019 12:57 AM
bjpotter
Oct 4, 2015 07:48 PM
sjorgens
Oct 1, 2015 07:54 PM
TheCardinal
Exterior Parts for Sale
Oct 1, 2015 07:40 PM
Blkdth87
Sep 16, 2015 01:40 PM
