what kinda fuel pump should i run??
Old Jan 17, 2009 | 12:15 AM
arozr600's Avatar
my fuel pump took a crap this morning nd im going to replace it this weekend, but i was wondering what pump i should put in it?? I have plans for doing a mild 383 in the spring nd still running the TPI plans to push around 400 to the wheels. I was wondering what pump would be good to put in now to support the motor to come and if its alot higher volume what fuel pressure regulator i should run while i have the stock 305 in it so it doesnt flood it??
Thanks alot,
Andrew
Old Jan 17, 2009 | 01:04 AM
ljnowell's Avatar
Re: what kinda fuel pump should i run??
Thanks alot,
Andrew
Your tpi uses a regulator with return, you shouldnt flood it.
Old Jan 17, 2009 | 01:53 AM
thunder-lips's Avatar
Car: 1989 Formula 350
Engine: building a 383 as of Feb. 09
Transmission: 700 R4, B&M shift kit
Axle/Gears: 3.23?
What I would personally do is replace the intank pump with just a stock replacement and then do a 255lph inline walbro pump to support the the system.
Old Jan 18, 2009 | 06:34 PM
arozr600's Avatar
i was just going to run a granatelli alot of ppl have been tellin me there pretty good any thoughts ??
Old Jan 19, 2009 | 07:00 PM
Axle/Gears: 3.23?
I am not very familiar with that one. Every one around here runs with walbro or aeromotive. Aeromotive can be pretty spendy though.
Old Jan 19, 2009 | 09:38 PM
arozr600's Avatar
cool cool thanks guys
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
theshackle
Mar 5, 2017 06:37 PM
Jae992
Aug 27, 2015 09:07 AM
92camaroJoe
Aug 13, 2015 06:07 AM
