please suggest a ca smog legalish cam
Old Jan 19, 2009 | 11:50 PM
slickfx3's Avatar
Car: 1989 Chevy Corvette
Engine: 383 SuperRam 10.7 AFR 195 220/229
Transmission: Fancy Smansy 87 Corvette 700r4
Axle/Gears: 3.33
383 stroker
89 corvette
zf6 speed
3.33 gears
afr 195 street heads
super ram
10.5+ to 1 compression
daily driver, never going to the track or road course, but lope sure sounds bitchin!!!
1 3/4 shorties
2.5 inch y pipes with pre cats and main cat
car not running yet, going from tpi to super ram considering a cam change before installing motor
this is what's in it now; should i rip it out? if i do; can i sell it??
custom ground comp
220/225 at .05
.535/.532 at 1.5 ratio
will be using 1.6 crane golds so the lift will be around
.571 and .566
114.8 lsa as per pro cam measuments ( this part i really don't like) and the corvette forum is bogged down..... so here i am a defector...
HELP!!!
Old Jan 20, 2009 | 09:31 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: please suggest a ca smog legalish cam
Is this Mason? That build sounds familiar.
I'd recommend the Comp XFI280HR-113.
Old Jan 20, 2009 | 09:46 PM
slickfx3's Avatar
Axle/Gears: 3.33
yes kevin, the engine builder goofed and didn't seal the manifold right, i didn't check the measurements until it was out (manifold), opting to go with a used super ram as per installer.
and revisiting cam demensions, delays delays....
thanks for the suggestions
Old Jan 20, 2009 | 09:55 PM
slickfx3's Avatar
Axle/Gears: 3.33
thanks found answers
italiano67
Dec 11, 2016 09:21 AM
michealleger
Aug 26, 2015 03:29 PM
camaro_rs350
Northern California
Aug 18, 2015 12:38 AM
mustangman65_79
Aug 7, 2015 09:55 PM
drathaar907
Aug 6, 2015 04:20 PM
