lunati cam opinion
Old Jan 25, 2009 | 12:22 AM
tryn2gofast's Avatar
lunati cam opinion
LunatiProduct Line:Lunati Hydraulic Roller Tappet CamshaftsPart Type:CamshaftsPart Number:LUN-54762Cam Style:Hydraulic roller tappetBasic Operating RPM Range:2,200-6,800Intake Duration at 050 inch Lift:242Exhaust Duration at 050 inch Lift:252Duration at 050 inch Lift:242 int./252 exh.Advertised Intake Duration:300Advertised Exhaust Duration:310Advertised Duration:300 int./310 exh.Intake Valve Lift with Factory Rocker Arm Ratio:0.525 in.Exhaust Valve Lift with Factory Rocker Arm Ratio:0.540 in.Valve Lift with Factory Rocker Arm Ratio:0.525 int./0.540 exh. liftLobe Separation (degrees):110Intake Valve Lash:0.000 in.Exhaust Valve Lash:0.000 in.Computer Controlled Compatible:NoGrind Number:RRA1-227-234Quantity:Sold individually.
Camshaft, Hydraulic Roller Tappet, Advertised Duration 300/310, Lift .525/.540, Chevy, Small Block, Each
im trying to pull double duty(play and drive) with this motor. anybody running this cam?
im still in the plan phase so any inmput is app.
383 scat forged bottom
afr 195.65cc comp. heads
750 qft carb
edb rpm air gap.
comp ultra mag rr1.6
looking at hooker supercomps. but the dyno dons would work better if i drop the car.
150-175 shot
3000 s/c
373gear maybe(
Jorlain
Oct 8, 2015 01:57 AM
88rscamar0
Sep 23, 2015 09:08 PM
Jlanz55
Sep 8, 2015 11:28 PM
john204481
Sep 7, 2015 03:22 PM
TheExaminer
Sep 7, 2015 08:34 AM
