What sensor?
Old Jan 25, 2009 | 07:34 PM
jbates346's Avatar
What sensor?
So i'm in the process of taking out my LB9 from my '88 IROC. I noticed a sensor right next to the oil filter. What the hell is that? I thought maybe the knock sensor, but thats usually on the passenger side tho. So what is this one?
Old Jan 25, 2009 | 07:36 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: What sensor?
Oil pressure sending unit/switch.
Old Jan 25, 2009 | 07:38 PM
jbates346's Avatar
Re: What sensor?
Ok so when the oil pressure is too low, that signal goes the ECM and shuts off the engine? Its not the oil pressure sending unit that goes to the gauge right?
Old Jan 25, 2009 | 08:23 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: What sensor?
No, when the oil pressure it high the switch will power the fuel pump in case the fuel pump relay fails. If it has 3 wires, then it's also the sending unit for the gauge.
Old Jan 25, 2009 | 08:25 PM
jbates346's Avatar
Re: What sensor?
No i think it only has 2 wires. Nevertheless thanks for your help.
HoosierinWA
Oct 7, 2015 10:15 AM
aaron7
Sep 30, 2015 09:15 AM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
dusterbd
Sep 29, 2015 08:40 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
