Cylinder head accessory bolt holes
Old Jan 27, 2009 | 01:16 PM
chevyracer8262's Avatar
I have a set of ported 2.02"/1.60" '462' heads without the accessory bolt holes. Can the accessory bolt holes be drilled and tapped and Is it safe to do so?
Old Jan 27, 2009 | 01:23 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Cylinder head accessory bolt holes
I'm unsure of what heads were used, but, yes, it's been done. The search features will no doubt find you the specific info you require.
JamesC
Old Jan 27, 2009 | 02:45 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Only if you're just missing one hole. If the heads did not have any of the holes, the material isn't there to drill & tap them, and you won't have a flat surface to mount the accessories even if you did drill and tap them.
Old Jan 27, 2009 | 06:51 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Sell the heads and buy something more modern. The newer heads can easily outperform those old heads and will be much better castings. Even a set of Vortec heads are better.
Old Jan 27, 2009 | 09:48 PM
chevymec's Avatar
Car: '92 RS
Engine: 350 carb'd
Axle/Gears: 4.10
If you are dead set on using those heads they made brackets that allow you to bolt your accessories up.
Old Jan 28, 2009 | 12:24 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
If you are set on using those heads, there are brackets made that can make the '69+ accessory setup work on heads without the bolt holes, though I can't remember who makes them. I have seen them though. 'Alan Grove' I think might be the name...?
Old Jan 28, 2009 | 06:29 AM
chevymec's Avatar
Car: '92 RS
Engine: 350 carb'd
Axle/Gears: 4.10
GM made the brackets also IIRC.
evilstuie
Jan 9, 2020 08:29 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
NinjaNife
Aug 23, 2015 11:49 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
