87 iroc starting problem
Old Jan 31, 2009 | 01:39 PM
smokenasty's Avatar
Car: 87 Iroc
Engine: 5.7 TPI
Transmission: Automatic
so i have an 87 iroc 5.7. no a/c and no emission. I bought a brand new battery today. when i go to start the car. It cranks then stops. If i keep holding the ignition theres nothing. I hear a the pump come on when i go to start and then nothing but the sound of something wineding up. All the fluids are good, batterys good. also the temperature gauge goes crazy when i go to start it it just jumps around. The voltage reader reads about 11. I cant think of anything. Any Ideas
Old Jan 31, 2009 | 02:02 PM
smokenasty's Avatar
Car: 87 Iroc
Engine: 5.7 TPI
Re: 87 iroc starting problem
ok so i fixed that problem now does anyone know how in the hell to get a broken bolt out of the thermostat housing. Its broken in the back hole on the engine itself not the actual housing. I didn't do it. lol. and it has barely enought threads showing to get any kind of pliers on
Old Feb 1, 2009 | 11:22 AM
ChoobinatoR's Avatar
was it the starter that was the problem? i dont have this problem but its annoying going to a thread, people posting solutions and ideas, thread starter tells us what he's going to check or do, then the thread dies... w/o a solution or fix known.
but as for the bolt, there's a set of tools you can use, they're like small drill bits and you grind away the middle of the bolt, then take a screw driver or something and un-thread the bolt out. not sure what they're called but somebody used it on my car when a bolt broke while torquing a bolt to my flywheel at 60ft pounds or so.
hopefully someone can chime in on this, cuse i know its out there.
92camaroJoe
Jul 29, 2023 07:57 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
92camaroJoe
Aug 13, 2015 06:07 AM
mustangman65_79
Aug 11, 2015 03:17 PM
mustangman65_79
Aug 8, 2015 12:07 PM
