Gasket Seals
Old Feb 5, 2009 | 07:37 PM
ceohill81's Avatar
Car: 1992 Chevy Camaro
Engine: V8 305
Gasket Seals
I just purchased 2 fel-pro intake sets ms90314-2 and ms93317. the ms90314 is for a 4 barrel set-up. i have tbi and use the 93317, will the front and rear intake seals in the 4 barrel set-up work for my 305 tbi block set-up. i dont want to use only the black rtv to seal up the front and rear. but that is what my set-up calls for. i would not mind using the gaskets and a little bit of rtv on the gaskets if they will work. any advice would be helpful.
Old Feb 5, 2009 | 11:08 PM
rezinn's Avatar
Re: Gasket Seals
My advice is to use the RTV and throw the gaskets away. That's what a lot of people do with success.
Old Feb 5, 2009 | 11:27 PM
Rolling Thunder's Avatar
Car: 86 T/A, 83 Z/28
Engine: 5.0 TPI, 350 2 X 4 bbl
Transmission: 4 speed auto, 5 speed manual
Axle/Gears: 3.23 posi, 3.73 std
Re: Gasket Seals
They will work but i would use the gasket plus RVT gasket sealer. Guarenteed no leaks period end.
sheachopper
Jul 31, 2019 11:27 AM
1Aauto
Sponsored Vendors
Oct 19, 2016 08:50 AM
1Aauto
Sponsored Vendors
Oct 13, 2015 03:06 PM
Dragonsys
Sep 25, 2015 03:51 PM
