HOT FUEL LINES & TANK
Old Feb 11, 2009 | 07:36 AM
firebird's Avatar
Guys,
I have a 1988 GTA with the 5.0L LB9. For some reason my fuel lines and gas tank gets hot while driving, and even hotter if the temperature outside is above 50 degrees. Of course this causes the fuel pump to whine loudly, and eventually the car just dies. I've changed everything from fuel pressure regulator, fuel pump, and fuel filter. Has anyone ever experienced this, or have an answer that could help me.
Thanks,
Jeff
Old Feb 11, 2009 | 11:15 AM
David 91RS/Z28's Avatar
Re: HOT FUEL LINES & TANK
Make sure the heat shield is still there to protect the tank from the exhaust. If not, that might be some of the problem.
Old Feb 11, 2009 | 11:23 AM
firebird's Avatar
David,
The heat shield is there. As a matter of fact I dropped the exhaust to get it away from the heat shield because my mechanic thought it was too close and causing the problem. I dropped it, but the problem is still there.
Jeff
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
Andrew6.688
Dec 13, 2015 10:59 AM
AkDrifted
Aug 17, 2015 07:45 PM
Kaweh
Aug 9, 2015 02:54 PM
