power steering question
Car: 1989 GTA
Engine: TPI 350
Axle/Gears: stock axle
I converted over from tpi to carb awhile ago. Now I am changing all of the accessories and I have a question about the power steering. Do you have to keep the super long hard line that runs along the radiator or can I take that out and use two short lines?
thanks in advance
thanks in advance
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
Re: power steering question
If I correctly understand what you're referring to, those are there to cool the power steering fluid, and should be kept.
Car: 1989 GTA
Engine: TPI 350
does every car have them? how is it cooling the fluid if it is just running along the outside of the radiator?
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
A lot do. Some people might not even know it's there. It cools via heat transfer. Fluid travels through the tube, the heat then passes from the fluid to the tube, where airflow over the tube cools the tube down.
colton_carlson
Mar 8, 2019 12:21 PM
backtothe80s
Sep 5, 2015 12:39 AM
