fuel injector cleaner waste of money??
Old Feb 21, 2009 | 09:07 PM
T/Atime's Avatar
Car: 91 GTA
Axle/Gears: 3:73
Ive always used injector cleaner along with number 1 fuel and throttle body cleaner. Is injector cleaner a waste of money. My car runs smoth and gets good fuel economy.
Any one against any of the above. (its a L98)
Old Feb 21, 2009 | 10:48 PM
Rolling Thunder's Avatar
Car: 86 T/A, 83 Z/28
Engine: 5.0 TPI, 350 2 X 4 bbl
Transmission: 4 speed auto, 5 speed manual
Axle/Gears: 3.23 posi, 3.73 std
Re: fuel injector cleaner waste of money??
Well unlike most fuel/oil/other additives ive heard fuel injector cleaner is actually a good idea. I think i remeber reading back a aways in one of the older car magaziens that they agreed it was a good idea. Is it neccessary, probably not is the money you spend on fuel cleaners less than the cost of the repairs and losses in fuel economy they are preventing, who knows its all speculation but does it help? Its my oppinion that it does help keep the fuel system clean and with small ports like fuel injectors lets just say its something i would do.
Old Feb 21, 2009 | 10:58 PM
Stephen's Avatar
Car: 87 GTA
I use it at random...Maybe 2 or 3 times a year. Just like I drop in a bottle of Restore at engine change time.
21 yr old car...185,000 miles...And still knocks down 16mpg in town, 20 mph Highway (with a tad in-town driving mixed in)
Is Restore & Fuel Injector helping? I dunno...But it sure isn't hurting.
And actually, I CAN SAY, Restore helped...I used to blow that white puff of smoke at start up EVERY time. Now it is pretty rare that I get a puff and even, its not NEAR as bad as it was before.
I started this "regime" 3 years ago, when I bought the GTA at 173,000 miles.
Old Feb 22, 2009 | 07:25 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
With all the additives in today's fuel using fuel injector cleaner is probably not necessary. I only use it about once a year. I only use Techron.
Old Feb 22, 2009 | 07:40 AM
J91's Avatar
J91
Car: 91 Z28,64ImpalaSS4094spd,67 Galaxy
Engine: Dart 415Profiler hd,cmprlrs,Hlly750
Transmission: Built 700R4, 3200 stall
Axle/Gears: 3:89 Moser 9"
Use Lucas...
Old Feb 22, 2009 | 10:27 AM
TylerP's Avatar
Car: 89 T/A and 97 Formula (sunny days)
Engine: 305 TBI / LT1
Transmission: 700R4 / 6M
Axle/Gears: 89 IDK / 97 3.73
I use Lucas to but one of the best ways to clean the system and remove built up carbon is to pour a quart of ATF in the tank at fill up. I've done it and I know of mechanics that have done this. The cars just run better afterward. I know,it sounds crazy.
Old Feb 22, 2009 | 11:56 AM
T/Atime's Avatar
Car: 91 GTA
Axle/Gears: 3:73
About the puff of smoke at start up (valve seals?) my car does the same. Restore is a fuel additive or oil? My car does not use much of any oil between changes @190,000kms but it does puff at start up. But every time i pull it out of storage it will not smoke at all from the tail pipes?
Old Feb 22, 2009 | 11:59 AM
Stephen's Avatar
Car: 87 GTA
The puff is valve seals, most likely.
I just know that mine reduced its puff, a few months after the first time I used Restore.
bryan623
Mar 22, 2021 06:43 PM
Jake_92RS
Jan 28, 2020 10:37 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
kyleb24
Aug 15, 2015 08:24 AM
Firechicken86
Aug 12, 2015 10:07 PM
